Life Expectancy for a Stock HO, 6 Speed
Have to pre-heat even above 40 degrees to start
NV 5600 Filler Port location
I see that most of the Bombed trucks have short (stock) clutch lives.
If the Engine (truck, tires, wheels etc. ) is left 100% stock, what kind of clutch life should one expect from the stock clutch?
3500, HO, 6 Sp. , 4. 10 towing 14,440# 5er.
1998. 5, 2500, SLT, 24V, 4X4, Auto, 4. 10 towing 35ft. 5er
On Order due May 1. 3500, SLT+, Green/Tan, HO, 6 speed, 4X4, 4. 10, towing package, camper package, E-brakes.
I had talked to a couple of Ram mechanics prior to purchasing my truck and they had all said 100,000+ miles (this was on the 5-speed however, since the six speed was pretty rare back then). Of course they couldn't comment on how the truck was being used. I can proudly state that it is a least over 20k though (my mileage).
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
I have a slightly bombed 5ver 12Valve and I have over 170K on the stock clutch. The first 2 years of it's life it pulled all the time, (90miles) and the rest of the time it's run mostly empty.
95, Kitty dead, #6plate, 5speed.
Since I doubt many, if any, have reached 100K on their 6 speeds, it may be a question like: "How many licks does it take to get to the tootsie roll center of a tootsie pop... the world may never know". Okay, so have any of you guys got to the tootsie roll center of your 6 speed yet? Worked hard I'd say the center would come much faster than light duty. Bombed vs. stock will yield much different results. Come on guys, how many licks?
2001 3500 SLT, 4X4, ETH Cummins/DEE, LSD, 3. 54, Quad Cab, Long Bed, Agate, Camper Special Group, Towing Group, Additional Body Molding on Bed, Line-X bed-liner.
"REAL TRUCKS RATTLE!!"
