If you want a lift just do it. If not don't. There are always people on both sides of the fence. And somebody always has a buddy with (insert wtf here). Nobody actually knows what its like to lift unless they have done it.
If you do lift, you should know it is not an easy undertaking and will take time patience and expertise and lots of tools. My 99 rolls on a 4. 5 inch skyjacker and after the springs broke in it actually rides nice(all lift springs ride kinda iffy at first, take some time, the good ones get better, I thought my syjacker's were crap at first but they have gotten much better). I tow with it. A gooseneck, usually overloaded too. 15k. Not all the time mind you but a couple of times a year. I drag all kinds of little stuff around, atv's, dirtbikes, horses, concrete mixers, water tanks, etc. . I lifted mine because i like the way it looks. I like the way it handles deep sand when I go surf fishing, it goes pretty much where ever I have the idea to point it. You will need to do your homework on the steering thorugh. I run PSC box and pump, Thuren trac bar and DSS box brace. Once it is all done take it to a heavy duty truck spring and alignment shop. They will do a much better job than chuck at Midas.
I put on my own lift. I also have a shop on my farm with a lift, a couple of welders, vertical mill and a few other doodads to make life easier. Don't try to do it in the driveway. It may be a drive but 4 Wheel Parts has a chain of shops nationwide and they are usually really good.
No it isn't the most economical thing with all the wind resistance but it still gets 18mpg. Yeah the tires make a little noise and I keep a 4 inch drop hitch in the rear to fend off cars and make it easier to get into the bed and I run Nfab nerf bars with steps so I can get in the cab but it's my truck and I like it just the way it is. I have been thinking about 40 inch tires recently though
