TDK, Both Mallory and Carter pumps have their proponents! if you are going to install a pusher only and replace the original pump with a block of aluminum or somesuch, then you would use a high-pressure pump.
If you are going to run the engine-mounted lift pump as well as a pusher, then a low-pressure pump is the one to use back at the tank. It only has to supply the original engine-mounted lift pump with some positive inlet pressure at maximum demand. (assuming the engine-mounted lift pump is functioning normally).
P4601HP: 14-16psi/100gph
P4600HP: 6-8psi/100gph
P4594: 6-8psi/72gph
MikeR, have you checked for a plugged filter? Perhaps you got a bad load of fuel. If not, it would be interesting to know if your last pump was the 'latest and greatest', or if it was old stock.
Vaughn, that's a cute little filter, but a Racor 645R30 filter/water separator like Big Bob installed would be my preference. I wonder if water in suspension in the fuel has any bearing on lift pump failures?
Bob Gill, Hello! Testing is postponed! I was unable to get the pressure gauge installed before the insurance ran out on the truck for winter; the plan is to record pressures starting from stock, through a new fuel pump (installed presently), then with Ray's banjos, then a modified system. As soon as the roads dry out in the spring, I'll be back at it. Unfortunately, my truck doesn't rack up many miles per year, so even the stock pump isn't going to wear out in a reasonable length of time. During the winter I'm freshening up the transmission as well as installing the gauges. Good to hear from you!
Has anyone ever seen a specification for Mean Time Before Failure (MTBF) on ANY of these various pumps?? I don't recall ever seeing the specification anywhere. Maybe it's time we started asking the pump manufacturers to supply this information! I'll bet I know what they'll say when they find out that we're pumping diesel through them... ... ... ... ... ... ...
What's required is a central facility that is able to closely inspect and test defective fuel pumps and report back to the TDR members with their findings. Perhaps the TDR could take this on as a service to its members.
