Kent Kuykendall
Just put in a Geno's fuel pressure gauge with dual senders and a switch. Thanks to the info on this list. This Group is great. The first short trips with it I was getting 14. 5 at idle and never below 9. Today I went on a 2 hour ride empty and it began to jump down to 3 or 4 lbs. at the lites, then would go back up to 13-14 if I would rev it up. Then it would go back down to 3-5 at idle again. this went on for several lites, then it stayed down to2-5 while driving and went down to 0 under short WOT. After the truck sits with moter turn off for a while (got fuel), it would go back up to 14 or so and then it wouldn't be long it would go back down to 2-5 again even at idle it would be 4 or 5.
Has any one else had a lift pump act like this or could the gauge be at fault?
This will be the 3rd lift pump for the truck. (120,000 miles). This one has only been on for 18-19,000.
Kent
Kent
