This morning fuel pressure gauge was jumping wildly between 5 and 9 psi at idle, 3 to 7 at moderate throttle and 0 at WOT. LP was replaced under warranty ~3 months ago and before today has always had 14 psi idle, 10-11 WOT. Was about +10* outside this am. Engine ran fine - nothing to indicate something might be wrong. About 25 minutes into the commute to work, the FP reading returned to pretty much normal. 14 at idle, 8-9 WOT. Gauges were installed about 2 months ago and haven't had any problems (yet). First thought wouldn't be the gauge because of how the reading was jumping wildly up/down at random and in-between wide fluctuations the typical pulsing from the LP or VP44 was noticeable and a bit more pronounced than before. But then again, the gauge is new too so it could be faulty somehow. Other thought was that the FP isolator or line to gauge might be frozen. Wouldn't think this could be since I used 60/40 mix of new antifreeze/water and it wasn't too awfully cold out (+10*F). Fuel filter replaced about 8K ago and I always fuel up (including last time) at a larger fuel stop that is frequented quite often by truckers so I would think (assume) that the fuel I have is probably ok. Tank is currently at 3/8.
LP going out again, and so soon? Last LP was replaced because it was leaking. Thoughts much appreciated.
-Deon
-Deon
