I have a 91. 5 that the lift pump went out, so I went down to the local part
store and got a airtex pump, put it on blead the system and she ran rough at
first then idle out fine. Shut in down to put the tool away and went to start
it again and didn't get jack it just crank and crank so I blead the system
again and it ran fine. So far I have let to figure out what it is, I have tried
clear line to see if I am sucking air and it showed that I was so I replace the
hard line with a soild rubber line from the tank forward and still the same
problem. O bye the way it can run all day after I bleed it at idle but you drive
it down the road and it will dye like it ran out of fuel. So I thought
maybe the pump wasn't strong enough for the engine so I bought a cummins
lift pump and still the same thing. I am looking for help with this
or I am going to put a 30. 06 AP round through the block. #@$%!
