To prepare for some diagnosis; a question. What diagnostic process do you use if the lift pump is not getting a voltage applied through its connected lead?
Is that voltage controlled by switching, or is it controlled by a computer? Are people ever seeing a lift pump not working because it is not getting its control voltage?
Do these trucks have a solenoid controlled fuel valve that cuts off fuel when the truck is shut off? I was visiting with a guy who had a 12 valve; he said his truck had such a valve.
