Details here: TDR Privileges
Question is what to do about it? Dealer is retrofitting to new in tank style, under warranty. What if anything should be done? FASS, or GDP? What to get for easiest way to monitor fuel pressure?
Easiest way to monitor fuel pressure is probably using the replacement fuel filter cap from Genos. With all that stuff you've got modified I'm surprised you're not already monitoring the fuel pressure!
If the dealer retrofits the in-tank pump, that should work for you (although with all those mods you really should be running something a little more robust).
