Engine/Transmission (1998.5 - 2002) Lift Pump Dead?
Engine/Transmission (1998.5 - 2002) Fuel Pressure
Engine/Transmission (1998.5 - 2002) clutch can't get 6 spd in gear
I've noticed that my lift pump doesn't hum when the key is in run position, I don't have a pressure gauge yet, and don't seem to have a low power problem, however every now and then I have a launch hesitation, is it bad or am I nuts? Also is it worth fighting with the dealer for warranty, I can purchase a new Cummins pump for $106. 00. 89,000 on the truck. What do you think? Thanks
Take it in and tell them about the hesitation, they may check fuel pressure and put a new lift pump on it.
GET A FUEL PRESSURE GAUGE!
Mine is biting the dust as well. Would you mind posting the part number for the cummins pump on here? Also, do you know of any webpage/threads which contain instructions/pictures of the installation of a Lift Pump. Thanks
i had the stealership replace mine yesterday. the only problem was the mech. first of all wouldnt believe my guage or put his on to test it. i dont know what happened, but the next day they replaced the pump under warranty. let them pay for it , those of us still under warranty.
