I'm out driving today, engine shutters just a little, does it a few more times, Fuel Pressure bouncing..... Figure Lift pump is going, race for home. Got to thinking, I filled the tank yesterday, maybe bad/dirty fuel. It's been about 10K since filter change. Drain the bowl, yank the filter... dirty and nasty, LOTS of grit in the bottom of the bowl. So I cleaned the bowl out, filtered some "Good" fuel into the bowl. Siphoned out about 3/4 tank, thats alot of jerrycans, glad I have extras. Put 10 gallons in the tank. She fired right up, pressure steady and rattling like she should. Need to see if the station will hook me up on dumping the fuel and at least a partial refund.
Was it Divine Intervention that the Lift pump is working or just dumb luck. If it was just luck I'd rather have the luck picking Lottery Numbers then I can buy all the pumps I want.
