Going to install pusher pump tonight and I was going to splice the pigtail that came with replacement LP to trigger the relay for the pusher. I put a light on the plug but doesn't seem to have power with the key in the run position. Can someone explain how to determine which is +? On the replacement LP pigtail there are numbers on each side of the plug... 1 & 2. There are no stripes on the wires that I can see but there is a yellow piece of tape on one wire if that means anything. Thanks!
mike
mike
