2001 truck has fuel pump in tank pressure at 4-5 psi Truck will not start code in the injection pump. Have to replace injection pump. What to do about the in tank fuel pump is a air tech pump ok. How can you convert it back to outside pump. Some said you could just hookup a pump outside and not remove intank pump. Try that does not work.
