Hey all...
I have read tons of lift-pump threads and related info, so I am a bit surprised and worried when I see my lift pump act as follows.
First off, normal for me was 13 idle, 10-11 driving and 7-9 WOT.
Just two days ago, I'm driving around and notice my pressure around 3-4. I think, crap, lift-pump finally going out at 41,500 miles. I have no mods BTW.
Well, then, the next morning, I disconnect, clean, and reconnect all connections to on my Westach sender under the hood. Start the truck up and I'm at about 13 lbs. I think, cool, just a bad connection. Well, here is where it gets weird.
I give it gas to drive away, and the pressure drops to 0-1 driving and 3. 5 at idle. I drive to work, order a liftpump from Cummins Rocky Mountain, and after work, go out to the truck and start it... again, almost 13 lbs at idle. As soon as I use the throttle to pull away from the parking spot, it all drops to 0-1 driving and 3. 5 idle again. It stays this way all the way home.
Any ideas? I have a lift-pump coming on Monday, but I'm wondering if it is something more major like a control board or something since it shows 13 until I use the throttle.
I'd take it to the dealer, but I wonder if it would "pass their test" and fail it. :-{}
Steve
p. s. I'm not driving the truck.
Steve
