Just got done installing fuel pressure gauge on one of the two ports on top of my fuel filter cap. Upon trying to prime the system the fuel filter bowl will not fill. Cycled key 10+ times and still no fuel at top of housing. Manually filled the filter... cracked 4 injection lines... crank crank crank... and finally started. Reopened test port to see if pressure/fuel was present. No fuel running out of ports while uncapped, engine running. Do i need a new lift pump or is it possible that the pump has lost prime enough to make it not work.
