Went out this morning to start my pickup... temp was about 32*F. Let the grids cycle, cranked her the normal time, but she didn't fire (need to start cycling twice, as I can't plug her in)... so, fired her again and she started right up. Went back inside and let her idle about 5 minutes... came back out and I had diesel dripping off the bottom of the front diff. !!!! So, I looked and looked and couldn't see anything, and was late for class as it was, and fuel pressure was fine, so I left. Came back to my pickup after class and I had a nice little diesel spot under the front diff again. Climbed underneath and it was all the way down the front drive line and on the transmission lines. So, I investigated a little harder there, but still couldn't find where it was dripping from... it was coming down from somewhere above the starter. Got home and climbed under and checked everything... can't find where it's coming from!!! All my banjos are tight, all the injector lines are tight... the only place that seems as though fuel has come out of it is the very bottom of the lift pump where the wiring goes in!
Anybody else have this problem? FP is still running 14 PSI at idle and 10-12 at cruise, and pump sounds fine when running.
Oh, after wiping everything clean I let it prime w/ a starter bump and nothing was leaking down from what I could see
What happened, and is there reason to go get a spare LP just in case?
Josh
edited to add: When it was dripping off the front diff it was a drip about every 2 seconds, so wasn't a slow leak... didn't get a good look at the LP when it was doing this though, so am not sure if it was coming from there or not.
Josh
