Lift Pump Part Numbers?
Trans temp guage
Anyone using the Bully Dog " Torque Dog"?
Checked My lift pump preassures on saturday, here are the readings.
Pre-Filter
Idle-10psi
WOT-7psi
Post-Filter
Idle-9psi
WOT-5psi
OUCH!!
I thought I read that you can install the lift pump for the Cummins motorhome engine, and it will bolt right up and no need to change the wiring harnesses. I am going to get a new pump tommorow from Cummins, and want to know if I should get this one or the one that is spec'd for our engines. If I get the motorhome one, does anyone have the part number. Thanks
Jason
