Engine/Transmission (1998.5 - 2002) Lift Pump Pressure Decreasing Over Time......How Low Is Too Low???
2nd Gen Non-Engine/Transmission Why in tarnation
Engine/Transmission (1994 - 1998) Turbo questions/help
Chief USA
I put a guage on the injector pump schraeder valve and check lift pump pressure at each oil change and fuel filter change. I changed my fuel filter today and ran my pressure check. I get 10 psi at idle and 6 psi lowest observed at WOT on a 5th hard pull. When I first got the guage year before last; the lift pump idle pressure was 15 psi and WOT minimum pressure was 8 psi. :confused:
I figure there must me some wear and gradual decrease in pressure over time and the pump still seems to put out good volume but how low is too low?
I haven't run the fuel flow quantity test outlined in TSB 14-002-03, but from the amount of fuel the system put out when I purged the air from the injector pump schraeder valve during the 25 second lift pump cycle; I would suspect that the pump easily can put out 45 oz. of fuel in 26 seconds. The truck has about 22,800 miles on it. The truck is bone stock.
I am thinking about calling the dealer and telling them about the gradually worsening pressure and see if they will replace the lift pump under warranty. Evidently 5 psi seems to be the replacement criteria minimum pressure.
Any comments, suggestions, or ideas welcome.
By the way, this time I tried adding 18 oz. of clean diesel fuel to the filter housing bowl before I reinstalled the filter. When I threaded the lid down, the fuel just did come up to the lid threads but not run over. All I did after I torqued the lid to 25 ft. /lbs. was to purge about a half cup of fuel from the injector pump schraeder valve during a 25 second cycle until I heard the lift pump load down and loose a few rpm. She fired right up and did not miss a lick. Oo. :eek: ;) Last time I followed the book instructions and spent about 2 hours purging air from the system after the injector pump ran dry and the engine died and would not restart. :rolleyes: :-{} :{
Figured I would bump this back up to the top. Was hoping to get a few replies with some information and experiences.
DC service techs will use the flow test outlined in the TSB, not pressure. If it produces the required flow, it is considered good.
I had a VP44 replaced under warranty, and the LP was determined to be good according to flow. I went to Cummins and purchased a new LP and installed it myself. Much better than killing another VP44.
Personally, I would go buy a LP, and change it out. Should be in the $150. 00 ballpark, give or take.
What lcoblentz said, I would change it regardless of what the dealer says. 6psi still is not bad but I would change it because in my experience it does not take long for the lift pump to die once it starts losing pressure.
Thanks, I called the dealer and have an appointment to bring it in to be checked and hopefully replaced this Friday.
I don't know what pressure is too low. Had a FP Guage installed on the lift pump today, I'm getting between 3 & 4psi at idle. Don't know for sure but think this is too low. Opinions?
Cheers,
OTRPU
At idle I would say that is too low. :eek: I usually drop 3-4 psi off the idle psi of 10-11, under throttle I can get 6-7 which scares me a bit but it has been this way since day one with the pressure guage on. If I had 3-4 at idle I would be checking in to it asap.
Altho I did have erractic prossure of 0-2 psi one time but that was when it was 15 below zero so I chalked it up to cold fuel but believe me I was watching it very carefully to get back up
I just replaced my lift pump at 60K. It would drop to 5 psi at idle and go to zero at speed. It even pulled the 216 code, twice. After a day or two of this the pressure would return to 15/11. My first trip to the dealer resulted in an $80 charge to investigate. They ran a flow test on the lift pump. Since they didn't find anything failing under warranty, I got to pay the $80. They tried to get the code to trip again and couldn't.
Couple weeks later, it happened again. This time I went to Cummins and bought a new lift pump. Easy install and no problems so far.
Now here is the neat deal an old diesel mechanic told me about. When I changed the fuel filter, he had me button everthing up, start the truck and open the fuel filter drain valve with the engine idling. Be sure to have a big pan under the truck to catch the fuel. This purged the air and any water and, from the volume of fuel that shot out, I'd say it's a pretty good flow test. I did this again last night when I changed the lift pump. Both times the truck never missed a lick.
I just replaced my second lift pump today. I replaced the first one at about
35,000 miles. I was getting erractic pressure readings on original. When I replaced it the new one had readings of 12 lbs. at idle about 8lbs cruising at 2000 RPM and the lowest I could bring it down WOT was 6 lbs. I to started seeing gradual drop in pressure 8 lbs. idle cruising 2000 RPM 6lbs. and WOT as low as 2 lbs. I now have 72,000 miles and I just installed second pump today. Results 16 -17 lbs at idle, WOT lowest I got was 10 lbs. Did not get chance to go cruising yet. I can not believe difference in pressure readings in the two different pumps I installed, parts man said the only difference in the newer one I installed today is the plug in connection on the bottom of pump.
