I am using my 50 psi boost guage to measure my fuel pressure so I don't know how accurate that is. I tested mine though and it showed about 6psi at idle and when running 75 down the highway it hovered around 2 psi. I replaced it and put in larger fuel line at the same time and used the aeroquip fittings. After that It still only showed about 9 psi at idle and about 4 psi at 75. What is everyones thoughts on this??? Should I try replacing it again or not worry about it? It drops to zero if I step on it hard.
Modifications include RV ECM, DDIIIs and PMax 2
