Hi all; I am here at Mom's, (translation- ULTRA slow dialup- search takes more time than I have at the moment), and I was wondering what the lift pump pressure should be? I hooked a line up to Mom's boost gauge (that is as of yet uninstalled
), and got a steady 7psi at idle, and light throttle. At WOT, 30+ psi boost, it sucked down to 5psi. Is this normal? I realize bgilbert has a 2nd Gen LP, but his readings were still higher at the get together last month. Anyone else? What are you seeing with your stock LPs?
Daniel
Daniel
