I wanted to know if any one else has had this experience with their lift pump. The normal running pressure is between 2 to 3psi, 4psi when backed off of the throttle (like slowing down or going down hill). If I hit WOT it goes to 0psi then jumps to 11psi until the high demand is gone, then back to the 2 to 3psi normal reading. I have installed 3/8 lines with AN fitting so there is less restriction than normal. I have also a Edge EZ box installed. The truck seems to have great power, 212 rear wheel H. P. on dyno without the Edge EZ box. There doesn't seem to be any performance problems now but I don't want to harm the VP44. Should I try a Aux. pump back by the fuel tank first or replace the lift pump and see what happens? What is the part number of the replacement pump that Cummins sells? Thanks in advance
