This adventure started out with the engine not starting after setting for a few days. It would start after priming with the lift pump but without bleeding. I temporally installed a 0-15 psi analog gauge at the banjo bolt to the filter to check the pressure.
It has good pressure at cold idle (8 psi) and a small bit of throttle it would climb to 12 psi and just after shut down the psi will wrap the needle all the way around and then slowly drop to zero psi. (climb past 15 psi >18psi?),This can't be normal!
My guess is the IP (VE) if feeding the pressure back to the top of the lift pump. But why, how?
Ideas, suggestions?
The lift was replaced July of 2017.
Ideas, suggestions?
