I had my lift pump on a 2002 24 valve replaced under warrenty with the new in tank pump that Dodge is using and when I drove the truck my BD Low Fuel psi indicator still came on. I went back to the dealer and was told that they only test for flow not pressure. I have connected a pressure gauge where the indicator mounts and I get 7psi at idle and 4-5 psi while running. Can ayone tell me what pressures the new in tank lift pumps run at?
