Not magic, just physics.
(back) pressure occurs when you try and move more volume then will flow through a given orfice. Max FLOW accurs when the load (VP) and lines can handle the FREE flow from the lift pump. Pressure is not your friend.
Think of it like this, a pump producing 1 GPM (assuming an ideal and constant viscosity) flowing a fluid though a pipe capable of flowing 1GPM will move 1 GPM. Easy enough! But, install a 2 GPM pump on the same 1 GPM line and you have (back)pressure of X PSI. And the flow will be = or < 1 GPM. Pressure is a measure of mismatch.
The same holds true for radio theory, a VSWR (RF equivalent of PSI) of 1. 1:1 is the same as 0PSI as measure AFTER the pumping device. A VSWR of 2:1 indicates BACK flowing voltage (think higher PSI) from the load (antenna).
If you dont belive this, do a search for "pumps, lines and what not". The man demonstrated that max FLOW occurs at 0 PSI back pressure measured after the pump.
DC knows what they are doing, FLOW FLOW FLOW is what the VP needs, not "Tim Allen" style of manly back pressure!!!
The inlet vane pump on the VP is a positive displacement pump, meaning that the vanes and decreasing area under the vanes will determine the fuel quantity of FLOW through the pump. If I remember correctly there is a pressure relief valve to bypass VP to keep pressure down.
Have a little fun (I did this little experiment), take the return line to the tank and run it into a container. Note how small the quantity is. Then unplug the LP (dont let it stop in a fuel obstruction position!!!!, check for a negative pressure (suction) at the VP!!!) and watch the return fuel. No detectable difference :-laf But some will argue that the "extra" fuel/pressure somehow magically "cools" the VP :-laf Those that hold to this myth dont bother with, they wont listen.
If you want to lower your VP temps add fiber washers (4) under the FF bracket, that will drop the inlet fuel temp about 30F. Then go Bobs route and add a fuel cooler between the filter and the VP.
My VP runs about 130F max on a hot tow. (yea yea, heat soak, whatever... I am not installing bilge blowers, NO ONE has given any evidence that a fan cools the VP INTERNALS!!, the closest was Tim? at City Diesel but he had a temp probe installed in the potting material only)
The real test would be a gauge that could read suction at the VP. 0 PSI is cool, suction is wayyyyyyyyyyy bad!
