Lift Pump Presure
Morning Radio
twister at 7200'!
What is the Min Presure that The Dodge Dealer will except in order to replace our lift Pumps. Under Load and WOT I get about 8 lbs on the output of the Filter. Is this below The Standard???
radar doctor
You might get better response to your question if you post it in one of the “Engine & Drivetrain” forums. You need to fill out your signature too so we can see what you have. Saves time as opposed to asking all the time.
The minimum accepted pressure is 8 psi. Even if you drop below that, you may have problems getting your local dealer to change it.
