Hi All.
I spent most all afternoon installing gauges in my 01 2500. when I was more or less done I turned the key and my lift pump won't cycle. It had been fine before. My thought is that I could have messed something up while wiring the gauges. The only wires I tapped into were the dimmer wire (maybe tan?) right behind the light switch, and an ignition on wire (I think blue) that I tapped into right above the plug entering the keys/headlights/open door buzzer.
What fuses/relays should I be checking. Thanks in advance.
Ben
Ben
