I went to the local Cummins dealer to buy a new lift pump. My truck is starting to hesitate under a hard pull and will cut out when accelerating hard. The tech at Cummins told me that the lift pump only operated when you turn the key on to prime the vp44 on start up. He said that the vp44 sucked the fuel form the tank. If this is true, then I certainly do not need the new lift pump. I have about 130K on the truck. Any input is appreciated!!!
