I change the oil & filter every 3,000 and the fuel filter every other oil change. Each time I change oil, I check the fuel pressure at the test port before the filter using a 4 year old Snap-on fuel test gauge. The fuel pressure has always been 14 psi ever since new, but this time it was 7. 5 psi. I checked it again with a different fuel pressure gauge, a Craftsman, and it reads the same, 7. 5 psi. The service manual says that the pressure should be 10 psi MINIMUM, (it is written bold and in caps). I take it to the dealer, and after 5 hours, the service writer tells me that there is nothing wrong, that it meets the spec. I tell him that I used two different gauges that are quality tools and that just can't be. Well, he made the mistake of letting me go back to the service area to see for myself. I found the shop monkey working on it. This kid starts my truck and shows me his test gauge and I was struck by what I saw. The guage he was using had the glass broken out of it, had a big dent in the edge that deformed the gauge by more than an inch, the dial was loose so that I could move it around and make it read anywhere within 30 psi, and was leaking/spraying fuel all over my engine compartment. This gauge was reading 10 psi. I told him to shut it down and asked them if they really thought that this gauge was useable? The kid said "this is a $200. 00 tool and I trust it". The service writer looked a little sheepish and said nothing. The service manager came in with his tie and crisp white shirt and asked if there was a problem. I told him what had transpired, and asked if there was another gauge that we could use when the kid piped up that this was the only gauge they had in the shop. I showed the manager the gauge and asked if he would trust it. He said that the gauge showed the fuel pressure to be at the lower spec, and the he couldn't justify to Dodge replacing the pump under warranty. I was stunned by this outfit. As a Submariner for all these years I know the value of calibrated torque wrenches and test equipment and I say that no Service manager worth his salt would even allow a tool like that in his shop, let alone say something like that in front of a customer. Anyway, I took it to another dealer and he said that the lift pump is not covered under warranty until after the 2002 model year. In other words, my 2000 is not under warranty. I know that you guys have had your 2000 lift pumps replaced under warranty, but I can't find out for sure if it is really covered or not. Nothing in my warranty information mentions anything about it. Looks like I'll replace it myself, the dealers here want $375. plus tax for the pump. Where is a good place to get a replacement, and does anyone have any information on warranty questions with the lift pump? Thanks for you help and suggestions.
Larry
Larry
