Had a lift pump failure on my '99 (87k miles) in May while in CT. Had Ted Jannetty install a Carter add on pump near fuel tank, and except for the loud sound from the pump all was well. Finally had time to get truck to dealer for replacement of failed pump, which was done yesterday 6/20. We left the add on pump in place and just disconnected the 12v feed. Drove home after installation, and then to our shop this AM (43 miles) with no problem. Started for lunch today and after two blocks engine stumbled and quit! Coasted to side of road, and re-connected wire to add-on pump, engine started and has run fine for rest of day.
Question: Has anyone had this problem with a replacement pump failure, and are there some bad replacement pumps out there. I know many will say the hell with it just run the add on pump, and I will consider that if I can figure out how to kill the noise. Don't mind the whistle or diesel rattle, but the pump is a killer!
Thanks for your help, Denny
