Engine/Transmission (1998.5 - 2002) Lift pump turns on when you turn key off
Engine/Transmission (1998.5 - 2002) No bus
BrandonF
I don't get stumped much but I am actually grasping at straws with this. When the happens the truck will not start in this condition?..... Any one gone thru this before?
Thanks
Btw it's a 99 24 v in sig
Assuming there's nothing wrong with the factory wiring (i. e: it's stock), then there must be something wrong with the ECM.
Can you supply any more details on what lead up to this?
Has the ECM been flashed or reprogrammed recently?
Did this start suddenly?
John L.
Well it just started recently reflas 3 yrs ago, that's the kicker there's no indicators to point to on this it has new ignition switch that we just did, thought it was culprit... I am thinking ECM And bypass lift pump circuit. It's my Hail Mary pass
Have you also noticed any odd behavior with the Wait-To-Start lamp?
Often when the ECM starts having problems owners report hat the WTS lamp remains OFF when the ignition key is turned on, and the engine won't start until the WTS lamp finally does come on.
If you know someone in your area with a similarly configured truck, you could borrow their ECM and see if the problem disappears.
John L.
did you check the relay for the pump?
Unless someone has changed the factory wiring, there is no lift pump relay.
The lift pump is supplied power directly from the Cummins ECM... no relay, no fuse... amazingly just a direct connection.
John L.
Jlandry the wts lamp does not come on when it is in this condition, have you been in this boat, looks like the ECM huh?
Thankfully I haven't been in this boat but I've read plenty of threads here on the TDR forum from other guys who have.
I definitely sounds like an ECM problem. If you can live with waiting to start the engine until the WTS lamp comes on, then you can bypass the ECM altogether and rewire to the lift pump to energize when the ignition is turned to the RUN position. See THIS POST for details on how to do this.
Good luck,
John L.
