lift pump types for pushers
Rear main seal leak.
help for newcomer
What type of pump is best for a pusher at the tank. Has any one tried a Holley In-Line Universal Electric Fuel Pump . or any of the Holley pump. Do not trust the stock pump any more after going throw three in one week on a stock truck. The pressure all were below 7 psi at wot in netural. :confused: :mad: :{
Steve, I don't use a pusher pump so I'll let that crowd give advice. What I do suggest is to replace the failing pump before you add the pusher.
Scott W.
I did not word that right. the fourth pump works great 10 psi wot in gear. I now want to and a pump back by the tank to push fuel to the stock lift pump. I am at the 155,000 km mark. at 160,000 km it is time to upgaded the power from the engine. need more power.
Carter #4600 7 psi at 100 gph
also pictured is a 30 micron filter with water in fuel sensor and a separate fuel heater. A filter minder to a LED guage on dash tells me when filter is clogged
<BR>
