hey. having the opposite problem on mine. Won't run when I bump the starter, but will run with engine running. my question on the relay is: if you look in the book it states that the pump has two duty cycles. it runs at 25% when engine is cranking. is this important or should I not worry about to much pressure at injecting port while cranking?
You're right. . the ECM sends pulses of power to the LP during start-up to keep the pressure down. With a relay running off the ECM you get those same pulses to the relay (the relay is triggered on and off) and the pressure is about the same. At least that seems to be what's happening.
I've been running my LP off the relay for 3 years or so and never had a problem with too much pressure. Much rather have the LP running off the battery than straight through the ECM.
You need to keep a spare relay as they can go bad too. I've had a few relays go south on me over the years but it was a quick side of the road fix with no tools required.
Mike
Mike,Can't understand the logic behind using a computor to supply 10-12 amps @ 12 volts to run a pump. Hell they didn't even put a fuse in the system.
When I bump the starter the lift pump will run for the 20 to 25 seconds with 12 psi. Start the motor and when the timer runs out pressure goes to 0. What could be causing this.
Thanks, Ron
Mike,
Wanna bet increasing profit somehow weighed in on the decision?
John L.
Wouldn't doubt that at all! Bean counters ruin everything they get their calculator on. If the engineers made all the decisions 90% of these problems wouldn't have happened in the first place.
Mike
