Lift pump?
These diesel trucks (Dodge) are EXPENSIVE to own!!!
I'm going thru withdrawal
Hey everyone,
I just had my lift pump replaced40k (under warranty) and my truck seems to still have a slight loss off power. I have an Edge EZ that I have on the middle setting. It just seems off? Is there anything else that should be checked? Thanx for the help.
what year is your truck? if it is 2000 or later you can get the code by on off three times with the key, dont start the engine. codes appear in the odometer. if you have 98. 5 or 99 you need code reader. could be vp44.
