If you needed a LP on a tight budjet and already had the Vulcan Relocation kit which bump would you prefer?
Holly Blue or OEM from Cummins?
lukesdiesel said:If you needed a LP on a tight budjet and already had the Vulcan Relocation kit which bump would you prefer?
Joe Mc said:For $119 you can get just the Walbro 391 pump, for another $20 you get the 392.
lukesdiesel said:I can get a brand new Holley Blue for $75... ... Can't turn that down... Just need to know what other fitings I would need with my Vulcan Kit to connect to the Holley.
ERuhl said:Which of course if used alone would damage the VP, so don't forget the 3-port pressure regulator and extra return line. Hardly appropriate for someone on a tight budget don't ya think?
Ncostello said:Cummins724... what engine does the firetrucks have? I'm assuming they dont have the ISB5. 9 which requires the lift pump to be on 100% of the time. Most bigger diesels only require the transfers to run for 30 seconds upon start up then they are off the remainder of the time. Which leads to long life on the pumps. Also firetrucks won't see the hours/miles of OTR trucks. Some do... but only in the busiest of stations.
VIPERBLUELX said:Does the Holley Blue require a regulator? How much fuel pressure does the Holley supply compared to stock?
