Lift Pump
Heads up-new dually bed on E-Bay
Rear Differential Leak
What kind of electric pump is being used to replace the lift pump on the 12-valve motors? I have a 97' with a bad pump and it needs repaired ASAP.
I would just replace it with another new mechanical one. They are inexpensive, have good pressure & volume, and should last a long time.
Ted Jennety tried an electric pump. He had trouble with the fuel heater leaking.
Chris T's race truck has an electric transfer pump. I think they had to bypass the fuel heater. Its fine if you don't live in a cold climate.
