lift pump?
G56 Leaking from the top (shift tower)
adrenaline is here
So I think I need a new lift pump. My girlfriend is on the shoulder of the Richmond San Rafael bridge with a dead CTD. "just died" "start it and runs for a minute and shuts off" alll gauges and lights are working. I am assuming it is the 193k mile lift pump? Cal Trans is currently pushing her off the bridge, I am home drinking a beer. My question is, if it is the lift pump what Air Dog do I replace with. 100 or 150? Eventually I will be runinng some sort of tuner and mild injectors after a transmission build. Unfortunatley these upgrades will not happen any time soon. If it is the lift pump I want to fix the problem with an upgrade.
With what you are planning to do to the truck do you think you will be over 550hp? If not I would get the Air Dog 100 because it is a very easy install because you have nothing to do with the tank just disconnect the factory line from the tank and connect the Air Dog line, no drilling for a draw straw!!! If you plan on running higher than 550hp I would call Pure Flow Technologies and see if the have their Air Dog II ready to be shipped, this is there new system that is pretty slick, Charlie e-mailed me some info last week and after reading through it is nice! The kit comes complete with everything to do the install, including modding you stock fuel canister!!
Hope this helps.
