I have a 92 W350 w/281k. About a year ago, my truck was having a hard time starting and would slowly dips up to the normal idle rpm and didn't have much power. I replaced the fuel filter and nothing changed. I then tryed to move the mechanical arm on the lift pump and would not move. I replaced the pump with a stock pump from Genos. My truck is starting to thave a slight sputter as I start it. It only lasts for a second, then runs fine. It has lots of power still. I replaced the lift pump almost a year ago. The fuel filter has 10k on last change. The transfer pump only has 7k. I don't have a pressure gauge to test it. Could it be going out already?
