Lift pump??
water seperator
Engine stalled no power (Question)
Looked under truck and hood, followed fuel lines to filter, just how big is lift pump and where is it located?? is it between block and filter, looked at geno replacement pump and dont see anything like it unless its really small??
If you still have the factory lift pump, it is mounted on the rear surface of the fuel filter housing. It's about a 4" long cylinder an inch and a half in diameter mounted vertically.
