lift pump
Engine/Transmission (1998.5 - 2002) New Torque Converter
Engine/Transmission (1998.5 - 2002) Chugging/Sputtering
I have 99 dodge 2500 6 speed had the dreaded 53 block purchased a good used 2001 block transfer my injection pump, turbo, injectors etc. all known good and now the lift pump wont run to prime the fuel system found out that the 2001 done away with the crank position sensor what do I have to do to get my lift pump to work ?
Pump should run for 30 secs. bumping the starter. On something else, did you install the 99 crank tone ring in the 01 ?. Cummins made that mistake on mine when they installed the 56 so they had to tear things down twice.
Thank you for the information just want to verify that you used all your electronics off your engine on the new engine, and can you buy a tone ring and install it on the 01 crank
