From what I've read here, the 98. 5's were/are notorious for VP44 faliures. I'd get a FP gauge and see what you have at idle and while putting a load on the engine while driving. I'm of the opinion that using more fuel won't hurt the lift pump, other members have different views. Adding more fuel will show a lift pumps weak points. For example, if the pump you have now is seeing 3 psi's at full throttle, under a load, adding a fueling box may bring those same numbers to 0 psi's or even vacuum numbers as the injection pump is now trying to suck the fuel it requires. This is a bad thing as the VP44 uses fuel for lubrication.
Things to look for with a failing pump are slowly declining psi's and fluctuating psi's under steady throttle.
Scott W.
