Hard to start , Low idle psi less than 12-15psi Low psi normal cruse speed less than 10 psi , Low to no ,3-4 wot - 0 psi (wot = wide open throdel) Some injector pumps will suck the fuel from the tank just enough to seem to run fine but that will not last for long as extra fuel is used to cool and lub the pump . Some lift pumps run but do not pump. some will jump around on psi guage. GET a Guage O to 16 psi and mount the sender off the motor to keep from shaking it to death. Lol Ron in Louisville Metro ? KYOriginally posted by AKDrifter
What would be the symptoms of a bad, or going bad lift pump.
