At 124K, here is my experience w/ LPs. At 9K the dealer replaced LP due recall of my particular LP. Installed a FP gauge not long after that. I probably got about 50K before the PSI started to slowly drop on that LP. I then installed a Carter 4601 back by the tank and it was great for about 30K and then when it dropped to about 12PSI, I installed another 4601, but it only produced 12PSI from the get-go. I ran it anyway for about 15 K and then it dropped to 5PSI so I re-installed the "old" 4601 and ran it for another 15K till it dropped to 3PSI:--) Yikes!!! So I then went to the local Cummins shop and for $120 bought a Cummins LP and it produces 16PSI at idle and sits at 14. 5PSI at 70-75 MPH. My truck is only lightly BOMBed at 350/824, so IMO a stock pump would be fine for a mildly BOMBed truck. You will need (3) weber fittings to run new lines from the rear mounted pump to the fuel filter though. You can get them from JEGs or Summit. I don't have the part number handy, but they are a 1mm x 12mm male to 3/8 tapered male fitting. HTH
