Ok ok after MUCH wasted time on the suspension, I am about two weeks out from pulling my 94 2x4 CTD and transmission out of the truck and dropping it into the limousine. What we are working with is a 1990 Lincoln Town Car Limousine, with a 97 front end on it.
I am going to build a sub-frame of tubing to hold the motor mounts, transmission mounts etc. And the stock Lincoln Core support is getting cut out just outside the headlights, and the 94 Dodge "U" shaped core support is getting installed about a foot in front of the stock lincoln location. That way all the stock Dodge hoses, radiators, intercoolers etc will fit when somthing needs tobe serviced. I am going to use hood pins to hold the hood down because the lincoln hood tie down is on the radiator support getting axed.
The exhaust is going to be tricky by my measurments. I have to remove the facotry Lincoln heater core/heater box. Good thing the limo has an AUX heater/AC unit in the back.
The physical parts aside, the wiring is next. I am plannig on using the 94 Dodge gauges, and removing ALL of the original Lincoln engine wiring. I have all the wiring diagrams for both vehicles, so that will be fun. Then to install the 94 Dodge facotry gauges, I am going to fiberglass the unit into the stock lincoln dash for now. A complete custom dash will folow after I make some money back
A few questions I have forgot the answer to or failed to look up: Does the 94 Dodge 2x4 CTD use the speed sensor on the transmission for the speedometer? And Besided the Engine computer on the firwall, and the transmission computer(havent looked it up yet) what other "computers" do I need? FYI: I am ase master certified and LOVE wiring, so this is not "above my head" I think. But it is alot larger then the few times I've rewired custom cars. Fun Fun Fun!
Thanks in advance
-Brandon
I will be updating this for my swap. Heres about how it sits, I am just finishing up some welding on the frame I built right now.
Thanks in advance
-Brandon
