Lifting a 2500 with RWD
Burnt Smell From Heater/AC Ducts
Tow mirror wont flip up
Hey gang, What's the maximum lift on these front suspensions on a 2500 without causing the upper "A" arm coming in contact with the spring perch ?. I don't want to change out spindles because then I'll need to purchase new wheels with less backspace, just want to do it with new springs and or spacers. Can't seem to find much info from other members lifting their 2 WD Rams. Yes I said 2WDs, lol.
You need stacks for that rig and in have em cheap. Took off my 2009 4500 before trading it. PM me if interested. :D
EDIT: Google this "2007 ram 2500 2wd leveling kit" and you'll get a bunch of hits. Of someone has done it, good to get their input, not sure many have.
Cheers, Ron
I put in 1 in. taller front springs from Coil Spring Specialties, in St. Marys KS. Didn't look like it did much. I was trying to level the bed rail to match my 5er. I also put in custom shackles to lower the rear but that's not what your about.
My front end guy said I could put as much as 3 in longer springs before there would be interference. It would ride stiffer though.
