lifting front end of 2wd an 1" or 2"?
Largest tire for stock wheels/truck ...
A.F.T. (website)
How can I lift the front end just enough to clear my 315s? As of right now it barely rubs the wells on turns and once I get some miles on it I'd imagine it will do it even more. Does anyone have and "magic" to gaining an 1" or a little more? Thanks for any help.
BTW these are on H2 wheels.
That's odd I have never heard of the 315s rubbing on H2 wheels. Revtek makes a pretty nice 2" lift for the front for about $120. Do a search on the user Yo Hoot, he posted install instructions.
revtek.com has a 2" leveling kit for the dodge for front only. I have seen some of the trucks that have them and they really look great. T-rex ( on sponsors page) also makes a kit for the whole truck, Lifts the front 2-3 inches and the rear up a little. That is an awsome kit. I think they say can go up to 35's. Is a little more expensive. Revtek is around 200 dollars and the t-rex is 2300-3200 dollars. If you can afford the t-rex it would look awsome and provides a great ride off rode. replaces the existing shocks with notrogene shoks all around and better springs and leafs. Hope this helps.
I put a 2" kit on mine, it raised it every bit of 2" or more. Can't remember what brand it was, it has been over a yr. (can't remember what I did last week most of the time if I don't write it down) My kit was around $200. They just replace the stock blocks or donuts that fit on top of the front springs.
I have a 2wd so I think thats why I am getting more rubbing than most, but I think its just on the wheel wells. Do These tires tend to throw rocks alot b/c of it sticking out?
I just picked up some H2 wheels with 315's as well. I just ordered a 1 1/2" coil spring spacer lift through 4wheelsupply.com
I have read that they work well for others, so I hope they give me enough clearance for the new wheels/tires. I may end up getting fender flares as well.
Turboboost, Does your new setup need fender flares? Did you lift the truck yet? btw: mine is 2 wheel drive also... do you have any pics?
