I've had a new pump(Cummins Part#3990105) ridin' in back for a year and a half just in case. Well, I decided to get rid of the original as pressure was wavering between 12-7psi and worse(5-6) when it got cold out before warming up. All pressure's are post filter.
I changed it from the top as I did the fuel filter also. What a PAIN, as there's barely room to do it. Anyway after I got it all back together I found a washer on the ground, same type as the one's between the fuel line bolts and fuel line's. Were there washer between the fuel line's and pump? If so one got lost and one ended up in my tool kit! :--)
Took a little to get it started but when it did the pressure rose to 14psi. Checked for leaks, none found, so off on a 15 mile test drive. Pressure stayed at 14psi and hit 16psi just before I got home. One thing, I got a LOT MORE EXHAUST SMOKE when I punched it, especially when shifting from 5th to 6th. Power seems the same, boost up around 26psi(WOT), which was same as before. I've never seen this truck smoke much like it does now, even after previous fuel filter changes. Seems the liftpump made a big difference in that aspect. I worry about the washer I found, but there didn't seem to be any room for one between the pump and fuel line. I hope it didn't fall off the bolt during install.
Those of you who have changed your pumps(OEM) let me know your thoughts. Thanks in advance.
