Introducing from our "Sourcerer" line of performance tested products,our new dyno & track tested light weight 24 valve pushrods. We've utilized a Chromemoly 4130 seamless tube. Then heat treated/hardened them for additional wear resistence & strength. This has allowed us to use a 5/16ths diameter tube to reduce recipricating weight by over 40% compared to the gargantuan arcaic oem pushrods. We've "pushed" these rods through pass after pass at 4100+ rpms with ZERO failures to date. We've invested in a large enough quantity to allow what we consider to be an exceptional VALUE for you 24 valve Cummins "rpm" enthusiasts. Our intended retail will be 147$ per set. Present plan is to blow out our 1st 500 sets at 126$ per set !
