I am looking to really get insane with my auxilirary lighting. I stumbled on the idea of using GE aircraft landing lights in 6" par46 housings while surfing the Ford board. Here a couple of threads that go into the details http://forums. ford-diesel.com/ubb/Forum17/HTML/003596.html http://forums. ford-diesel.com/ubb/Forum17/HTML/000104.html My idea is to use a GE 4522 290,000 candlepower lamp in a 6" housing on a seperate switch and use the H7604 110,000 candlepower lamp wired to come on with the factory hi-beams. I know that they fit a par36 housing, but I don't what that equates to in inches or if it is sold by an off-road company. The only housings I have been able to find are music lighting systems. I would like to get the 6" par46 and the par 36 housings out of the same company line so they look matched on the truck. I could go with the par46 version of the 110,000 candlepower lamp, but I have heard that the fillament is to thin to stand up to the vibration and impact of a truck, whearas the par36 H7604 halogen is a much longer lasting lamp. Or maybe I've just gone crazy or run out of legitimate projects for the truck. Any ideas?
Added on edit - you are probably thinking "why doesn't this fool just get some regular off-road lights?" The cool thing about this way of doing it is that the GE 4522 lamps can be had for a measly 27 bucks apiece. That means I could put together the whole 4-lamp system described above for a couple hundred bucks with the housings, relays and switching. Comparable candlepower off-road lights in the same 4-lamp setup would end up costing close to a grand.
'00 2500 reg cab LB 4x4, 5spd, LSD, Hot Poweredge, 275 injectors, Warn HS9500I winch, Trans4mer grille guard/winchmount, TracRack, Line-X OTR, G-tech, Loadsaver, and a bunch of other crap I don't technically "need" Name a factory option-I don't have it!
[This message has been edited by Arcticat (edited 12-25-2000). ]
