I have a power management computer in my RV. When the battery bank is down by around 50%, the onboard converter will charge at nearly 40 amps when hooked up to shore power. (Right at its rated capacity) I get slightly less running the external generator.
With the same level of discharge, when I hook the trailer to the truck, the computer never shows more than a 2. 5 amp charge. Is something in the truck limiting the flow of current to the trailer? Do you think that running a larger wire from the battery to the hitch pigtail female would make any difference?
Thanks in advance for your thoughts?
