Engine/Transmission (1998.5 - 2002) limited slip differential
Engine/Transmission (1998.5 - 2002) MAP sensor removal
Engine/Transmission (1994 - 1998) drive shaft yoke measurements
My truck rear end "grabs" a lot when you turn on pavement (empty or loaded)and is hard on tires. The gentlemen I bought it from said he only added one bottle of the "slip additive. " Is that enough and should I be feeling all this grabbing with a limited slip differential or should I add another bottle of slip additive? What is the rule on this?
Thanks in advance.
Greg Davis
