I have a 96 dually with an lsd in the rear. I have had the pinion seal replaced three times in the last year and a sleeve put on the yoke once. My question is this, recently the rear feels like it is grabbing when I turn a tight radius and apply power. It's the same in forward or reverse. I'm wondering if a bottle of friction modifier will solve this, or do I need a rebuild on the lsd. The dealer said they topped off the diff fluid, but I didn't lose that much lube. The leaks were weaps at the most. Also, I am thinking it's time to replace the diff lube and am wondering if a good synthetic will act the same as the modifier. Do these axles have gaskets on the rear diff cover or do they use silicone? If silicone is the way to go, what kind and color is best? What is the volume of oil needed?
Thanks,
Travis
Thanks,
Travis
